Still making some progress... Plane is all covered, Pics soon.
Was stalled however by a radio problem. I need the P-Mixes on my transmitter to make the dual elevator servos work, and the mixes are broken
Problem solved however, ordered a Futaba 9C to replace my 7C (which I will give to my dad) Now I will have enough channels and mixes to have this thing set up the way I want without aving to y-harness too many things
Staying with 72Mhz for now... Never have to worry about Freq conflicts since where I fly there are at most 15 people there on a "fly in" type day, usually just me and my dad, or a friend. And I saw a $6K Plane get destroyed when the RX was interuppted (or something) by a large radio beam that runs nearby our site. The signal was apparently lost, though the engine did not go to idle as in normal fail safe, and the TX/RX could not re-aquire signal before it went in. I could be wrong, but as I understand, he had has the same thing happen on a 72 Mhz PCM reciever a few weeks before, (lock out with no idle) but as the plane obviously survived that one I assume that the TX/RX picked up immediatly after the plane came away from the "Beam"
