Once and for all...which paint is fuelproof?
Any enamel type paint will go on better if you warm the paint up a little before spraying. Take your rattle can and put it in a pan of warm water for a few minutes before spraying. That should minimize orange peel.
Also, spray light dusting coats. Orange peel is caused by paint that is too thick (not enough thinner) or from spraying thick coats.
