RCU Forums - View Single Post - Strap it or screw it on?
Old 12-23-2007 | 11:09 AM
Rodney
Default RE: Strap it or screw it on?
If you use the proper size bolts and have no gap between the fuse and wing, nylon bolts are far better than rubber bands, even for a trainer. On your particular plane, 6X32 Nylon would be more than adequate to retain the wing and; should the inevitable crash occur, the wing bolts will shear with no damage to either wing or fuse caused by the attachment. I use 10X32 on my bigger planes (1/4 scale) and they are more than adequate for up to 15 pound airobatic planes.
