RCU Forums - View Single Post - Max-s .25 in a flite streak ARF
Old 12-23-2007 | 02:42 PM
gcb
Default RE: Max-s .25 in a flite streak ARF
Assuming you are going to use it as-is with the throttle open, it will have a bit less power than the FP. The Max-S was known to be a pretty powerful baffle engine and the Flite Streak was designed to fly with a baffle .19 to .35. That said, give it a try on the 60' lines. If it can't hack it, then decrease the line length.
Make sure the engine is broken in with a few short "heat-cycle" runs if it is new. Since it is iron/steel, you might consider using some castor in the fuel also.
BTW, some guys are flying the ARF Flite Streak with a FP .15.
George
