RE: Pentathlon Kit Build
Time to work on the bottom of the fuse. There are three simple sections to add to the bottom of the fuse....the chin cowl, the pipe tunnel section, and the aft bottom foam deck. In order to fit everything properly, I framed up the chin cowl and pipe tunnel assembly and dry fitted them to help position the bottom rear deck. The bottom rear deck will also need to have a cutout for the aft end of the pipe tunnel..so having the pipe tunnel assembly handy will make this much easier.
Start with the chin cowl parts and carefully assemble the frame work. No need to sheet it yet...sorry for the fuzzy pictures.
The pipe tunnel section can also be assembled without the final sheeting.
