Start up
Hello all,Marry chrismas
I installed the esky3100 motor and the Hobbywing 25amp esc along with a telbeHH gryo. This is the smoothest bird I have onwed so far,But do have a few ??? to ask
The blades dont start to spin untill 1/2 throttle is this normal?
With the HH gyro I have the three wires from the gyro pluggrd into channel 4 and tryed the single yellow wire plugged into shannel 5,but with it plugged in the hh gyro wouldnt hold the tail.So I unplugged the yellow wire and turned the gryo up as far as it will go,Now the tail will hold with a little drift.??????????
I did the programing of the esc with the programming card that you can buy for the hobbying esc.
Thanks All
