RCU Forums - View Single Post - Mini-Telemaster conversion
Old 12-25-2007 | 09:46 AM
AMB
Default RE: Mini-Telemaster conversion
OK guys Merry Christmas, Christmas eve spent wrapping the last few gifts, then FINISHED the mini tele the OS 10LA is installed per the mock up , made both wings non aileron and aileron the aileron has a 30oz servo 22 oz on rudder and elevator and a little sub micro
12 oz for throttle, there was an issue slop, in the rudder and elevator this was caused by bowing of the tubes, going thru the bottom for access secured then to a former and end of issue, 3 oz hayes tank also added 1/8 square bass wood along to sides of fus at top really
no flex there now 3 oz hayes tank perfect fit also went to 2 1/2 lt wt wheels. clevis to rudder and elevator sullivan 2 mm got rid the the plastic ones, 1/8 triangle stock rounded edges where rudder glued to stab no flex here, out of time so got to sign off and get on with Christmas, will post pix later ,yes berg mini 4 channel rec, battery under servo tray balance perfect no weights needed martin
again a great Christmas to all
