I have been an aircraft mechanic for 17 years and an r/c builder/flyer for 20+ yrs so maybe I am being a little too critical but when I lay down $$$ for what is described as a QB ARF I want to just throw a bottle of glue in the box and shake it!
I would just like to have someone else verify that this is an isolated problem with my hinges and my stab not parallel to the lower wing. I know several of you have kits so bolt the bottom wing on and slide the horizontal stab into it's slot and see what you find. Check your hinge lines and make sure you have all thousand hinges in line with center.
Kent
