ORIGINAL: Spetz
ah I see
Thanks guys
And, my boat now, the prop sits 8cm back from the hull on an outdrive system that the prop turns with the rudder
But that part there wears out way too quick so I want to change it over to a fixed prop setup
Should I aim to get the prop sitting about 8cm from the hull again with the stinger?
Does this outdrive put your prop below the hull?? Or coming out of the back of the hull (transom)??
How far behind the hull that the prop is placed, changes how the boat will ride. I do not have enough experience to know what happens at different length though.
Sean
