RCU Forums - View Single Post - spinner prop washer allow 1.5 turns on the nut
Old 12-26-2007 | 12:03 PM
broke_n_bummin's Avatar
broke_n_bummin
Default RE: spinner prop washer allow 1.5 turns on the nut
That's a big problem with MAS props. Use an APC, Evolution or Zinger prop. If you're adamant about using an MAS prop, then you might have to either get an extention or run it without the spinner.
