RCU Forums - View Single Post - spinner prop washer allow 1.5 turns on the nut
Old 12-26-2007 | 12:54 PM
horace315's Avatar
horace315
My Feedback: (15)
Default RE: spinner prop washer allow 1.5 turns on the nut
i agree if you are gonna use a spinner get yourself an extension and the spinner adapter setup that cgretired has posted is a good setup they are a little small but will work the spinner is the prop nut. apc prop centers are much thicker than mas props.i like the metal spinners that have the bolt adapters you use a setscrew in the front center to tighten down the spinner.
