RCU Forums - View Single Post - Pentathlon Kit Build
Old 12-26-2007 | 08:29 PM
  #57
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
Time to sheet the chin cowl. Before sheeting, make sure you have added the little ply donuts at the back for the mounting pins. You can start with the 1/8" balsa sides. Sand the top edges of the side pieces flush with the curvature of the lite ply frame. If you want to sheet the bottom with a single piece, you may want to preform it. I choose to plank with small width pieces.
ID:	834571   Click image for larger version
ID:	834572   Click image for larger version
ID:	834573   Click image for larger version
ID:	834574   Click image for larger version
ID:	834575   Click image for larger version
ID:	834576   Click image for larger version
ID:	834577   Click image for larger version
