RCU Forums - View Single Post - Fasst system problem
Old 12-26-2007 | 10:19 PM
alburman
Default Fasst system problem
I've been using hitec with no problems but decided to try 2.4 to eliminate any ignition noise problems. I got the 6 channel fasst system and immediately ran into a problem. I use an rcat switch to control the engine ignition and usually connect it to either channel 5 or 6. On ch 5, although I can operate a servo, it wont actuate the rcat switch. The flap switch operates nothing. I can connect the rcat switch on ch 1,2,3,or 4 and the switch will work perfectly. Any help out there?
Al Burman
