Fasst system problem
OR
I've been using hitec with no problems but decided to try 2.4 to eliminate any ignition noise problems. I got the 6 channel fasst system and immediately ran into a problem. I use an rcat switch to control the engine ignition and usually connect it to either channel 5 or 6. On ch 5, although I can operate a servo, it wont actuate the rcat switch. The flap switch operates nothing. I can connect the rcat switch on ch 1,2,3,or 4 and the switch will work perfectly. Any help out there?
Al Burman
Al Burman
You can force this to work if using the ignition in channel 5 by doing a Pmix to negate the Gear switch.
You would need to do a Pmix with Gear as Master and Gear as Slave at negative -100%, leaving the switch assignment ON.
Now if you go into your second Pmix and make Master Flap (CH6) and Slave Gear at positive +100%, and leave the channel assignment ON, your Flap switch should activate channel 5.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,
Krysta
OR
Thanks, I received an easier fix from Brian. He fixed the problem by lowering the end points on ch5. I set the epa to 50% up and down and it works perfectly now.
Al
Al
