RCU Forums - View Single Post - Fasst system problem
Old 12-27-2007 | 01:45 PM
Krysta
Default RE: Fasst system problem
You can force this to work if using the ignition in channel 5 by doing a Pmix to negate the Gear switch.
You would need to do a Pmix with Gear as Master and Gear as Slave at negative -100%, leaving the switch assignment ON.
Now if you go into your second Pmix and make Master Flap (CH6) and Slave Gear at positive +100%, and leave the channel assignment ON, your Flap switch should activate channel 5.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
