RE: Xtreme Boom Tail Motor on CX2
I would not wire it off a motor. Here is a thought. You can buy a set of easy lights which are controlled by the 5 channel and then see if you can tap the motor into the led circuit. Hmmm. Then you could turn it on and off plus you get a pair of neat spot lights. The easy lights are under $20 shipped. You would just have to make sure that the motor does not draw enough current to destory the circuit board of the easy lights.
