RCU Forums - View Single Post - Engine For TOPCAP
Old 04-11-2003 | 10:58 PM
sport10
Default Engine For TOPCAP
I bought my Webra 50 GT at my local hobbyshop. It was 149.00 then but the price has been dropped to 129.00 recently. When running this engine for the first time you might have to lean the low speed needle from the factory recommend setting to get it through the midrange. The recommended setting tends to loadup the midrange badly but fixing this is easy. Just run the engine where the engine is loading up and lean the low speed till the engine takes off. You might want to run some castor in you fuel till the engine is broke in just in case of a lean run.
