RCU Forums - View Single Post - Servo Replacement??????????
Old 12-28-2007 | 09:03 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Servo Replacement??????????
Agexpert,
I wasn't trying to say that it isn't possible to have the slop in the servo. I was pointing out that he simply needed to ensure that it was indeed the servo that had the problem, or if it was the linkages. If it was a problem with the linkage the problem would still be there AFTER he changed out the servos. It only takes a few seconds to check the linkages BEFORE replacing the servo. If you reread my first post you will see that I did indeed advise him to replace the servos AFTER checking the linkages first.
Ken
