Crazieflyer,
If trying to get your originally purchased plane flying gets to be too frustrating, then I too recommend the GWS Slow Stick. For $35 you get the kit and a GWS S300 motor. It assembles in about 4 hours or less and everything you have purchased/own will work except you'll need a larger battery pack - 7-8 cell, 800-1100 mah.
It has an aluminum fuse stick and foam wings and tail feathers and a 46" wing span. Flies very well and is quite durable/repairable. Spare parts are available and of course the whole kit for $35 gives you spare everything.
I didn't mention this at first because I know the feeling of purchasing something and immediately everyone tells you what you should have purchased and not how to fix what you have.
Best of luck. Please post to this thread what you find is the problem on "motor cuts off on full left rudder" - that one really intrigues me.
Sierra Gold
