RCU Forums - View Single Post - Sky Fly by Fly Zone
Old 12-28-2007 | 05:55 PM
j.m.
Default RE: Sky Fly by Fly Zone
Got a new wing today, as well as some 2mm control rods, dubro quick links, and an ElectriFly 3mm prop adapter with a 5mm output shaft mated to a APC 6X4 electric pusher prop. This goes very nicely with my upgraded motor, and the new control rods greatly increase precision.
I got the prop adapter to fit my motor by placing a smallpiece of aluminum tube between the motor shaft and the prop adapter. I cut a slit all the way down the side of the tube so it would compress with the prop adapter for a snug fit.
The new prop is not only more powerful and efficient, but it is also quieter when used with the prop adapter since it is moved farther back from the fuselage. (only about 1cm.)
I recommend this prop for anyone who flies a sky fly because they will see an increase in performance and runtimes.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPVF3&P=7
