RCU Forums - View Single Post - Pentathlon Kit Build
Old 12-28-2007 | 08:19 PM
  #58
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
The bottom of the vertical fin can be glued in place as shown. Sand a small flat area into the bottom rear deck. Carefully align the fin with the rest of the fuse. A small ply plate is provided for mounting the tailwheel later. Some filler and sanding will be required around the base of this piece.
ID:	836034   Click image for larger version
ID:	836035   Click image for larger version
