RCU Forums - View Single Post - Moving a servo hole
Old 12-28-2007 | 08:52 PM
stump3r's Avatar
stump3r
Default RE: Moving a servo hole
Easy as pie, remove the servo horn, drill out the hole your moving to then install the linkage and throw the servo horn back on.
One quick tip however. Before taking the servo horn off ensure you are at 90 degrees, then when you reinstall the servo horn same thing 90 degrees and all will be well.
