E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Moving a servo hole
Old 12-28-2007 | 08:36 PM
Default Moving a servo hole
I am just trying to figure out how I get the push rod out of the servo hole. Do I unscrew the white arm of the servo?
Or do I have to remove the servo altogether. I am working on a CX2.
THanks!
Old 12-28-2007 | 08:42 PM
Default RE: Moving a servo hole
unscrew the white arm & reposition your link if it is easy or you can get to it just do it with the arm still in place The Key is becareful don`t force
Old 12-28-2007 | 08:52 PM
stump3r's Avatar
Easy as pie, remove the servo horn, drill out the hole your moving to then install the linkage and throw the servo horn back on.
One quick tip however. Before taking the servo horn off ensure you are at 90 degrees, then when you reinstall the servo horn same thing 90 degrees and all will be well.
Old 12-28-2007 | 08:56 PM
what do you mean by servo horn. THe white arm is the horn?
Old 12-28-2007 | 08:59 PM
stump3r's Avatar
[sm=wink_smile.gif] Yeup that's the critter, the little white arms...also called horns.
Old 12-28-2007 | 09:03 PM
thnx, if I move one side should I move the other side?
Old 12-28-2007 | 09:10 PM
stump3r's Avatar
Yeup! That's how alot of us have ours set up now.
Little touchy on the tx the first few times you fly it however you will really like how responsive it is.
Old 12-28-2007 | 09:22 PM
Yes to all the above,
You are changing the distances of the pushrods to the swash, and You'll find that You will have adjust them. Keep the front canopy off and adjust the aileron until it stops running to one side; then adjust the elevator one until You have to trim most of the way forward with the trim. Then with the canopy on, You will slide the trim back to compensate for the off C.G. of the canopy; hopefully somewhere back to center.
Gary
Old 12-28-2007 | 09:38 PM
okay, moved forward/backward servo hole one forward. It was the last hole. I left the arilion alone. Did a quick test to make sure everything works and got 20 minutes on 2 batteries now. I will let you know what I think. These things are so incredibly easy to work on. A lot easier than my old rc cars. THis was the first time I took it apart. Did not mess with rods, but I know how to get to them now.
thanx, it is great when you have online support.
Old 12-28-2007 | 11:08 PM
Moving out 1 servo hole is like flying another heli; You will love it ! !
Watch the blade clack!
Old 12-28-2007 | 11:14 PM
Wolfpackin's Avatar
I would just add that with the linkage moved out a hole or two you've increased the chances of blade strikes/clack.
I would seriously consider a flybar mod to counter that.
I have moved my elevator linkage out two holes and still do not get blade strikes.
I think this is mainly due to my shorter flybar.
