RE: Planking!
I've built these exclusively with CA. Place the planks with medium CA... if any difficulty, use a dropper (I use an oiler with a hypo needle) to place a drop or two of CA kicker in to set the glue. With the porous wood, there is often enough air to keep CA from setting by itself.
Sometimes I find a place where I need to wick thin CA in under a plank edge... usually no issue with getting the CA on top. Worst area is under the flare of the bow, where planks tend not to sit flat on the underlayment, and end up looking a little bit like clapboard. OK, but make sure the plank edges are secured to one another, or they'll be springy when you sand them. This operation is likely to get glue on top.
But after sanding, you'll not find much problem with the stain. Dumas's water based stain seems to sit on top anyway, as opposed to reallysoaking in, so it works out ok.
Pat M
