RCU Forums - View Single Post - Pentathlon Kit Build
Old 12-29-2007 | 12:40 PM
  #61
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
I did get the landing gear mounted. If laid out early on, the landing gear can be carefully clamped to the landing gear plate. The plate already has through holes for 6-32 blind nuts, so just use these as drill guides. If the gear is not handy early on, there is a 1:1 scale PDF file for the gear template included on the CD. For best prop clearance, you will need the Bolly F3A Long for an electric setup. The Bolly F3A Electric will do fine for nitro.
You will also see that I did a bit of rough sanding around the nose. Some fill and final sanding and the nose section will be complete.
ID:	836472   Click image for larger version
