RE: Mini-Telemaster conversion
Final touchs on the mini tele decided ti run the exhaust all the way to the rear 5/16 thin wall Al. tubing (tip) by mounting the dubro exhaust deflector backwards long end to the muffler
you do not need to put a sweep in the tubing lines up perfect with bottom of Fus. 2 brackets bent up and screwed to body hold it fine just a very slight bend to clear elevator horn. I also use J and B weld as a cement to the exhaust on the OS 10 and a quick tie no slip or leaks here will post a pix but left my camera at our inlaws on Chistmas have to get back martin
finally a pix 10x4 wood topflite prop lots of pull only turning 8200 but quiet
will drop to a 9x4 to get the rpms up a bit but thing will fly fine on the 10 incher note I put the OS Max 10 conversion in
will bench the LA10 not quite right, there is a carb issue we had an exhaust leak it was running down the gear and over the wheel that is resolved now nice and dry
