ORIGINAL: vamp131
Hi I would say your rudder is the wrong size i have two on mine they are only 2" but about 10" high i have tried using one on my 1st air boat no good turning circle was huge with two it can turn on a dime
the way you have your rudder set up with cause the boat to flip over im sure someone on here will help you better than me but you want two rather than one
..Hi..Same Boat? I actualy Started to make a Double Fin,But there`s no way I can finish that by tommorow..Boat Flipped.[X(]I hope your Wrong ,but probably Correct LOL..The main thing is, that the Boys get to use it a bit ..then I can Re-engineer again Later...
