ORIGINAL: osterizer
No prob, man, just trying to avoid going around and around
. The best place to start is to begin with a newly initialized heli model, and do nothing to d/r, epa, pitch or throttle curves, hold, revo or gyro (leave them all at defaults). Set the swash type to S-3 and reverse the throttle channel, then take a read through section 13 of the EHBG mentioned above (
www.swashplate.co.uk to download); whenever it mentions specific radios, you'll want to pay attention to the 9C instructions (for example, when setting the swash AFR), but consult the 6EX manual for where the settings are (they're similar settings as on the 9C, but the menu structure is different). The Finless vids on CCPM setup take you through it in more detail.
If you run into difficulty following those, post the question up please. It would take a lot of typing to reproduce the material in those two sources, though, and it probably wouldn't be as good in the end
