RCU Forums - View Single Post - THE FINAL STRAW
Old 12-31-2007 | 11:26 PM
evan-RCU's Avatar
evan-RCU
Default RE: THE FINAL STRAW
Did you look at the link I sent in your first thread? Is there a pin and a "grub" set screw holding it in? If not that IS your problem. All it takes is one missing bolt, nut, screw or pin and you'll have a very dangerous machine that could really hurt you. Fix it correctly before you try to start it again. if you do not have the patience to fix it correctly then maybe you should sell it.
