multi engine throttle servos
hello,
after i few years off from building i am starting up again on several multi engine projects.i have used 2 servos in a y harness for twins using futaba 135 servos[mini] can 4 servos be uded off a double y connecter for throttles on four engined aircraft?also what servo has replaced the 135?or is there another sevo recommended for mounting in small space in nacelle for just throttle?access will be limited and there will be vibration from the engine on the nacelle?needs to be reasonably priced.
