ORIGINAL: AirmanBob
98 c5
Try this:
Well, if you're Pro looks anything like my Pro you don't use 3-S as your swash setting. You MUST use 1-S.
The transmitter settings should be like this:
RevR screen:
chan 1 nor
chan 2 nor
chan 3 nor
chan 4 rev
chan 5 nor
chan 6 nor
D/R
chan 1 100%
chan 2 100%
chan 3 100%
chan 4 100%
EXPO
chan 1 0%
chan 2 0%
chan 4 0%
EPA
chan 1 70%
chan 2 40%
chan 3 100%
chan 4 60%
chan 5 100%
chan 6 35%
TRIM
all chan at 0% to start out (will change when you fly and trim)
N-TH
1 - 0%
2 - 50%
3 - 70%
4 - 85%
5 - 90%
N-PI
1 - 10%
2 - 30%
3 - 50%
4 - 50%
5 - 68%
I-TH (idle up throttle)
INH (inhibit this while learning or face disaster)trust me on that.
I-PI
Blank
HOLD
0% (set a zero so that if you bump the THHOLD switch by accident you don't go to a high throttle setting. With this switch in the forward position (towards you), your throttle stick will not work).
REVO
INH (don't use with a heading hold gyro)
GYRO
INH (if you have an inflight adjustable gyro then you use this to switch between Heading Hold and Rate gyro.
SWSH
1-S You MUST use this setting if yours is mCCPM like mine. Check the photo and see servo positions. If they are same as mine use 1-S only.
NOTE: These are all settings that will get you up and hovering when your throttle hits about the 50% position. Later, when your hovering well you may want to experiment with these settings. Be SURE to write all these down BEFORE you go changing anything.
Good Luck,
Bob
Man, thanks so much this will help. I just completed the installation with the heli, do I need to set positive/neg at 8 degrees? and one more question d/r i've only got ch 1,2,4 I don't have ch.3 is that rihgt. Thanks again.
