RCU Forums - View Single Post - Sig Ultimate Fun Fly
Old 03-06-2002 | 06:34 PM
jmulder
Default Sig Ultimate Fun Fly
If you loose power(dead stick) you ARE landing RIGHT THEN. It does NOT glide at all. As far as the taped servos.....I taped the servos on as per instructions then I cut a small slit in the plastic at each end of the servo and stuck a plastic pull tie through and around the servo and tightened it up. Works great. It might not be needed but it sure makes me feel better about it.....John
