RE: Vertical Sync question
With vertical sync on, the frame rate and monitor refresh rate are in sync hence only 1 frame is displayed per refresh. This feature is useful when there is a significant difference between the monitor refresh rate and the frame rate where "black lines" could occur. Vert sync is not needed in your case, as in the case of most users
