RCU Forums - View Single Post - tool for starting/holding tiny screw heads?
Old 01-02-2008 | 07:10 PM
kdc
Default RE: tool for starting/holding tiny screw heads?
For holding and starting small screws nothing beats a 'pearl catcher ' also called a pick up tool. They are the gadgets with 3 wire prongs which open when the plunger is depressed. I think jewellers use them. They hold servo screws firmly enough to start them off . Invaluable tool.
There are plastic or metal case versions available (in Britain ) from Proops www.proopsbrothers.com and often seen at exhibitions. Cost is 1.50 pounds (plastic ) or 3 pounds( metal )
