RE: Help!!! I need help setting up a MX 400 Pro
98-C5
Well your pitch settings depend on how much heli experience you have.
If you have zero experience then I'd try for about positive 8 (+8) and
negative about minus 3 (-3).
You don't want to much negative pitch because when you panic and slam the
throttle to low , you'd SLAM the heli into the ground and that would cause a lot
of damage.
Also, as a new heli pilot you should dial in 25% negative expo so the heli
will not be to sensitive. That would be on channel 1 and 2.
Leave the d/r settings at 100% for now. D/R is useful on airplanes but not
so much on heli's.
Once again...these are just suggestions to get you up and hovering. Later
you will want to experiment.
Bob
