RCU Forums - View Single Post - MK Beetle Build
Old 01-03-2008 | 05:12 AM
T Brooks
Default RE: MK Beetle Build
Hello
Pics of the pre-fab bits. F/G Belly pan and pipe exhaust and top and bottom turtle decks.
Also the parts for the plug in tails. The beetle has a neat mechanism that allows the tail incidence to be adjusted after the plane is built. It has a pivot block at the front spar and a jack screw at the rear spar. The adjustment range is about 6mm or 1/4in.
Thats all for now.
Tarquin
ID:	840862   Click image for larger version
ID:	840863   Click image for larger version
