RCU Forums - View Single Post - Replaceing Plastic Swingarms
Thread
01-03-2008 | 06:32 PM
1
pzrwest
Aug 2007
1,439
Cardiff, ON, CANADA
I got a set of metal swing arms for my HL Tiger1. After removeing one of the stock swingarms I noticed there was no plastick spigot that a screw screws into. My Tiger1 has a machine screw with a shank and a washer. When I try to install the metal swing arms the screw's shank section isn't long enough to clear the backside of the hole and when you tighten the screw the swingarm will not move. When I compare the plastic swingarm to the metal one I see the rear section of the metal swingarm is slightly longer than the swingarms that came on my Tiger1. The only solution I can think of is to grind down the rear section. Here are pics of the stock swingarm, screw, washer, and mounting hole on the side of the tank. Suggestions????
Reply
Like
pzrwest
View Public Profile
Send a private message to pzrwest
Find More Posts by pzrwest
View iTrader Profile
