RCU Forums - View Single Post - HIGH RATES LOW RATES
Old 01-03-2008 | 06:39 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: HIGH RATES LOW RATES
Your dual rates are used while in flight. You would set them up so that low rate is a smaller surface deflection. I usually set my planes up with high rates being what the plane maker has recomended and low rates at about 60 percent of what is called for. If you are going into 3D flying you will need to know how to use your dual rates and when. Good Luck, Dave
