ORIGINAL: PatternPilot
We have looked at that plane in the past and depending on the fuse at least the one we saw there would be alot of work in to making the fuse as a plug then making the molds to pull new kits from.. There is a pretty good cost involved also for prep and tooling resin and mold prep then to pull the new fuses from molds.. The foam cutting is very easy , and not many other parts needed, that could be cnc cut, etc....
Unless there is a big market usally around 100 units it is hard to justify the cost... But I'm sure if someone wanted to front it.. it can be done...
Scott Anderson
Perfomance Model Aviation
I just thought everyone should read the above statements twice...
