RCU Forums - View Single Post - Mathcbox? Is it really needed?
Old 04-10-2003 | 11:34 PM
rcplanefan
Default Mathcbox? Is it really needed?
BobPHX and Planefan what transmitter/rx are you guys using
I have a 10X. I used to have an 8103, and I must admit that depending upon what else you have plugged in, it might be a problem. Send a message to Doug Cronkhite's (Doug, I apologize if I spelled your name incorrectly) SA list--there are lots of JR team members monitoring that list and you should get a pretty quick answer. If you can't use your TX to mix the rudder servos, drop the $44 and make it easy on yourself.
Ken
