ORIGINAL: rolyjr
Hi Isaac,
See you have been quite busy since I have been away! Great progress and attention to detail.
Regarding the honeycomb you are using, please could you let me know what thickness it is, and also whether you vacuum or press. Another question - do you run 4.8v or 6v systems. I am looking at putting in the 6v as this seems to be the trend to get the most out of the servos, using the Jaccio switch and regulator.
Roly
Hi Roly
Here is the link to the manufacturer of the honeycomb:
http://www.acp-composites.com/
These are the materials I use:
LP-21 1/8" Graphite/Balsa 225g 12" x 12" $28.00
LP-31 Glass/Nomex Panel 1/8" Thick x 12" x 24" $30.00
LP-37 Glass/Nomex Panel 1/4" Thick x 12" x 24" $30.00
LP-40 Carbon/Nomex Panel 1/8" Thick x 12" x 24" $41.00
I am going to use the ThunderPower Prolites 7.4 V 730 mah (TP730-2SPL) and PowerBox Digi-switch:
http://www.powerbox-systems.com/e/po...itch/start.php
Regards
Isaac Najary
