I was able to get panel set up on the wing jig. One change I did make to the structure was to redesign the front wing dowel hold down system. A 1/4 in thick balsa rib was cut and a pocket created for the 1/4 in diameter dowel. Once the wing is covered the dowels can be installed easily and accurately.
I like how you did the dowel, I'll have remember that one! Nice build so far!
FB
