ORIGINAL: ldgasp
Eddie, Do you know of step by step instruction son how to change it?
its pretty easy,
1. take the engine out and take the clutch bell off and replace back the same way with the single speed bell
2. take the 4 bolts off that hold the trans in
3. you may need to take the top plate off, try to change without doing this but it may be hard to get the drive shafts back in the trans
4. put it all back together.
its fairly simple, the trans is a direct fit to the 2 speed
