RCU Forums - View Single Post - C.F. OUTER SHAFT; Extended to kill 2 problems
Old 01-06-2008 | 08:00 PM
goldslinger
Default C.F. OUTER SHAFT; Extended to kill 2 problems
http://image2-6.rcuniverse.com/e1/ga.../lg-125612.jpg
http://image2-6.rcuniverse.com/e1/ga.../lg-125613.jpg
http://image2-6.rcuniverse.com/e1/ga.../lg-125614.jpg
Here's my latest heli with a 5mm extended Carbon Fiber Outer shaft and a 5mm extended Titanium shaft.
This let's Me use a standard and LIGHTER micro heli upper head instead of the extended 5mm XTREME head that is heavier.
The idea of XTREME'S 5mm extended head was to prevent blade/flybar strikes and it works beautifully! However, it is a bit heavier than a standard aluminum head. Extending both shafts let's Me accomplish the same thing without the added weight.
I dropped enough weight to install the Carbon Fiber/ Aluminum Main Body Frame New from Microheli; (Thanks Shane for telling Me about that) that I have coming. Then, install my invisible wired lights on the new frame.
Then this thing wil really Bling !
Thanks!
Gary
