RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 01-07-2008 | 12:27 AM
  #518
tewalker01
Default RE: Composite-ARF Integral, kinda build thread
Kevin,
According to my instructions - "Each stab also has a matching carbon sleeve inside it, with a blob of epoxy/microballoons on the bottom of it to reinforce the position where you must install the M3 X 12mm stab retaining bolts, approx. 75mm (3") in from the root rib." I measured my stab and found that 4" (measuring from the outside edge of the stab - the root rib is an 1/8 " indent) puts you right on/just inside of the the inner rib. Any reason why you chose 4" rather than 3"? The reason that I ask is that I'm getting ready to do my stab.
Nitpicking as always,
Terry
P.S. See you out at the field if the rain ever stops.
