RE: dragonflyer 5 ti my questions
They didn't make it clear in the manual.
2)you land it and press the arming button while it is still armed holding the rudder full left and down.
3) Basically, the switch and startup procedure make an AND gate. So if you flip the switch to enabled and enable it on the df, it will fly with ti. Otherwise, it wont. But in midflight, if you've programmed the ti, you can turn the switch back on to turn the ti on
This is what i think. I may be wrong.
