HL Tiger electrics
Hi,
I have a small problem in that my Tiger main board does not seem to communicate with the turret (mainly!) The red(?) LEDs come on and work OK, changing from blinking to constant when I press the starter. But none of the turret functions work. If I apply a voltage direct to each motor - turn and elevation -each works OK. Neither work when I connect to the loom.
This is the second main board I've tried with the same result, so I do not suspect the board.
Has anyone else had this problem? Any help would be appreciated.
Thanks.
