carsondoc. I have used "wood glue" (elmers glue-all) on all my planes and not had a filure due to the glue. Had some because of the joint being bad, but the glue did not fail. I've tried the CAs and use them to "tack" parts togeather, but always go back and
glue-em with elmers. CA fumes makes my head hurt, and I can't see it once it drys. I'm never sure of its structural integrity especially on a less than perfect joint. Any good white/yellow 'wood glue" is all ya need IMO. Problem is that it takes a long time to dry. Using a CA to hold things togeather while the
real glue is drying, just lets me move-on to the next step sooner. Basically I do my re-glue with elmers when I'm using CA to "tack". If I'm not in a hurry, I just use the elmers and there is no need to re-glue joints that gravity does not effect. You will always have to turn the wing over and re-glue the other side, then let that dry.
Q.
