RE: Need rubber O ring
You might have luck at a local hardware or home depot. I'm not sure if their o rings will be fuel resistant, some might.
A little trick I've used before is to cut a small piece of fuel tubing and slide it over the needle valve so it covers the threaded section completly. Might work for awhile until you can get an o ring. ENJOY !!! RED
