RCU Forums - View Single Post - Need rubber O ring
Old 01-07-2008 | 11:01 PM
Insanemoondoggie's Avatar
Insanemoondoggie
Default RE: Need rubber O ring
I`m pretty sure the size you need is a 3mm outside diameter with a 2mm inside. I have a Magnum .52 4c thats giving me the same problem . The HS and LS needle uses the same o-ring.
Bruce is right , that is the part #
